3 members (cmayna, TUTS 59, 1 invisible),
146
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | Well the weather here in central Missouri has finally given me a break. Its time to get back into the shop and get the 53 back together. I started back in November and pulled out the engine from the old girl. Prior to me getting her, she had sat in the woods for around 20 years. After a lot of work I managed to get her back on the road, but the old girl leaked more oil than gas it used. For this reason, I decided to tear her down and replace all the seals. The engine is work is just about complete, just need to adjust the valves and put some engine tin's back on. Was hoping to go through the old 3 speed to this winter, but it will have to wait till next winter. I did get a new clutch, pressure plate, disk, and throw-out bearing to install. The trans is easy enough to pull back out later for a rebuild. I am feeling the "itch" to drive her and will have to scratch it soon! Hate seeing her in pieces! 1953 3100
Larry
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I also love the pictures that follow the truck! Yum!! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | Did I link to more than my truck?? Whoops! Sorry about that. I just checked the link and seen what it was. That's my other hobby, I love cooking.
Larry
| | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | Loved looking through the photos of your truck. Interesting to see the clutch pedal and the indicator for an automatic transmission at the same time! Looks a lot like my truck when I started. Unfortunately I didn't see any food!
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road. Tim
| | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | You know it would be interesting if these old girls could talk. There is no telling what someone has done to them. When I first seen my truck my first thought was it was a hydro, but after taking a second look I could see otherwise. If you look carefully at the indicator on the column you may notice it is backwards. No telling what the story is behind that! By the way I removed the food photos but if you feel left out I will link you to them! ;-)
Larry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Larry, Maybe there is a reason your shifting world might be reversed? Powerglide indicators and Hydra-Matic (not Hydro-Matic) indicators had the gear indicators in different sequences. Some Hydra-Matic indicators with name/title on themSome Powerglide indicators4 forward gears on 1953-55 GMC/Chevrolet Hydra-Matic? 2 forward gears on Powerglide? Maybe a former owner had to replace the indicator and mounting the wrong one in reverse was "helpful"? | | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | Yes could of been. Maybe they scavenged the column out of another truck. I am familiar with the different gear pattern on some shifting selectors. I had a 51 Buick with the Dynaflow and if I remember right Reverse was all the way down on it too.
Larry
