1 members (joe apple), 110 guests, and 3 robots.
Topics128,089
Posts1,056,139
Members48,435
Hi again from Germany,
I'm working on the 4-speed crashbox, unfortunately the thread in the rear end of the mainshaft has a slight damage. The first few threads are worn but there is enough thread length to use a longer screw. I cannot find the matching screw and so i cannot measure, how many TPI the screw should have. The old online chevy manuals database shows this:
[image]https://abload.de/img/u-jointtomainshaftwwu60.jpg[/image]
Hmm, bad quality, but the thread sizes vary between 20 or 24 TPI depending on truck type. What thread size applies to my 1946 half ton truck?
Thanks in advance again for your help!
Sven
Best wishes
Sven
Crusing in the Passing Lane
Get the OD of the bolt to start with in ", if it is .5", could be .5"/20 which is a NF thread. .375"/24 is also a NF thread.
Ed
I just checked an output shaft I have here , from a '46 , it is 3/8" x 24.
Thank you both, instead of the original 1 3/16" length I'll use a 1 3/4" long screw to compensate for the worn threads
Sven
Best wishes
Sven
If there is room to do so, try putting a stud, not a bolt into the output shaft, and secure it with a thread lock liquid like Loctite. Then use a nut to secure the universal joint. That way there won't be as much stress on the thread in the shaft as it will be a "one time" installation and the nut will be the part taking the tightening stress,
