2 members (DadsFirstPickup, Stovebolt48), 97 guests, and 1 robot.
Topics128,050
Posts1,055,670
Junior Member
Junior Member
I found a sunvisor in a box of parts that come with my truck,(it was a big box). It does not seem to be a Fulton there is no center adjustment. It's 1 piece that bolts to the rain guard, and seems to hang down a little lower. Anyway, I've decided to put it on my 48 1/2 ton and was wondering what color is normally on the underside of the sunvisor. The outside color of the truck is orange, (bright orange). I'm afraid the reflection from the hood to the inside sunvisor through the windshield my be too much. Maybe that's why they make sunglasses! My question is, has any stovebolter had a problem with a bad reflection? Would it be best to paint it a flat black? You all have been great answering my stupid questions, and any help with this will be greatly appreciaded.
Ex Hall Monitor
Ex Hall Monitor
It's a very flat, almost OD green. It's about the same color as zinc chromate primer.
475wls1, Tiny has the correct response...See
My visor...The only modification I made to the visor was I ommitted the top molding, and I spooned in a 6 inch peak to match the peak in the
roof...I get no reflections, but You will need to
buy a traffic light viewer. Guide makes them, and
are still available....Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
