6 members (MRMEROTH11, FAST55, 1955 1 Series, Hotrod Lincoln, greenie-reddy, Otto Skorzeny), 127 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1260333 03/27/2018 4:32 AM
After reading a few posts and doubting that I was going to get a good fitting one I finally took the plunge and ordered a headliner from The Old Car Centre in Langley B.C.
It came rolled up in a tube so I unrolled it on the downstairs carpet and left it for a week pressed flat using a couple of encyclopedias!
The centre rib was cleaned up repainted and waiting, I installed the headliner into it and punched in the ends at the punch marks and then taped it tight in place.
Time to install I removed the seat and frame and it slipped in place, and with a little finesse the back half piece slipped in place. I installed the back trim and tightened up the inside windshield trim.
No trimming or miss aligned holes perfect fit!
After reading about wearing gloves I would also recommend a beanie or block heater ( touque) to prevent marks on the new headliner.
Drivers side sunvisor is next I don't think I'm going to install a passenger one as there is't any holes anyway.
I'm not sure where they ordered it from but I would not hesitate to recommend ordering from them.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
For those of you in your 20s, an Encyclopedia is the original "Search Engine" used by your Grandparents. wave
Great job on the install.
And on occasion we still use them, as we'll as the world atlas computerdeath
Thanks I'll try to get some pictures today. pix
Pictures of the installed headliner.
Fox Offline
Verrrrrrry nice!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Doyle
Job well done! Thanks for the photos!
Now you've given me some incentive to get mine installed.
Thanks again
Moderated by  Dusty53
