Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (papas52, klhansen, 55shaker, WingWright, 2 invisible), 120 guests, and 3 robots.
Topics128,280
Posts1,058,602
Members48,492
#1259762 03/22/2018 11:36 PM
Since I saw a post of a truck I worked on about 25 years ago on another site. I thought would share this. The 60-66 k truck powersteering swap. I have put dozens of ps boxes on these trucks over the years. A few had the gm pattern Saginaw box. But cracked frames and the inability to get the proper length pitman arm or steering arm for the closed knuckle axle led me to another solution. Now having worked on every make if 4x4 over the years. I took note of common parts, engineering differences. What was problematic, etc. So into the parts bin I went. First thing I noticed that the old dodge and international 4x4 trucks never had frame troubles. No cracks. Next I noticed that international had a bunch of different pitman arm lengths. One specifically was perfect for the closed knuckle front arm on the gm trucks. Next while that international stuff was good. The 72-77 mopar 4x4 trucks had a mount that worked really well on a gm frame. So I started grabbing mopar spec reverse rotation Saginaw steering boxes. International pitman arms. And combined with a little machine work. That is reaming out the tapers on the arms to fit a 70-91 gm draglink. Shortening the drag link by about 1-1/2 inch. I could put together a setup that maintained the turning radius with the closed knuckle front. Did not crack the frame with hard use or big tires. And looked so clean I could convince people I had a rare factory ps truck.... lol. So here is my latest install. On my 384 cube big block v6 gmc. With a 3 speed brownie. 205 t case. Rear no spin. Front powr loc. Front and rear winches. All wrapped in a 65 gmc body. More details will follow.
Reverse rotation box mounted on a 65gmc k1500
It would be very easy for someone to think that was stock. Very good work.
Cant wait to see entire truck Barry
The body is going back on the frame soon. I have it rolling around on dollys at the truck farm. I keep getting customers needing work! This has been the year of 4l60e rebuilds. 6 so far. And jeeps... Jeep stuff. Crazy year. Usually my winters are more for me. But soon Joe. And your facebook page will see it first.. Also Joe there are 2 more k trucks at the truck farm. Stuff I have not shown to anyone. One is a really cool apache 10. With a hot 261 I built. Other is a one of a kind apache 30. That's almost a roller. That truck is what happens when I got bored..
The Box and arms Look good!! Where do the Power steering hoses go to the box?? See no holes??? Im doing a 63 K 10 and working on p/s for it!!
The hoses have a 90° bend upwards. The ports face the frame. I use factory 62-66 fenderwell clamps. Installed in the factory location. I cant post a pic of that now. I am on vacation for 2 weeks.
If there is any way u could post a pic I would appreciate it!!
