8 members (DadsFirstPickup, GradyB, GRNHydra, Jay R, TUTS 59, JW51, Ponchogl, Leo),
82
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I’m getting my steering wheel ready to paint. It has a few very small cracks. What is best to fill these with? It’s a stock steering wheel.
Thx Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Others have used epoxy filler with good results.ðŸ›
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Get it sprayed with bedliner. Way tougher and more flexible than paint and the cracks shouldn't telegraph thru as they very likely will with paint over epoxy filler. The problem with the filler is it's essentially impossible to get good adhesion in the cracks that have been soaking up dirt and crud for 50+ years, so the cracks will still be there just smaller.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Kevin I plan on opening the cracks before filling. I’m looking for something a little more refined than bed liner. Martin Epoxy is what I was thinking of but wasn’t sure if a product was preferred over another.
Thx Don
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Bed liner can be put on smooth or with texture, and is available in a bunch of colors besides black. The stuff is tough. I plan on using it on my running boards and possibly my steering wheel. Opening the cracks is a good plan. Hope it works well for you.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Bed liner can be put on smooth or with texture, and is available in a bunch of colors besides black. The stuff is tough. I plan on using it on my running boards and possibly my steering wheel. Opening the cracks is a good plan. Hope it works well for you. Okay that’s good to know. Thanks Don
| | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | I used PC-7 epoxy filler on two different wheels. Open up the cracks, clean really well and fill with the epoxy. Painted with top of the line acrylic enamel with hardener. That way you can color match to the interior or column. Glossy on the wheel, semi-gloss on the column and dash. Both painted about 10-15 years ago, still look great. I think Eastwood now sells a kit for doing this. Plan to spend 20 - 30 hours on the project but it is worth it. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | 2-part 3M panel adhesive works great for this. It has a similar amount of hardness as the steering wheel material which makes feathering it out to a perfect finish a dream. I then spray with epoxy primer, then pain it.
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | 2-part 3M panel adhesive works great for this. It has a similar amount of hardness as the steering wheel material which makes feathering it out to a perfect finish a dream. I then spray with epoxy primer, then pain it. Carl I’ll bet that works great but these cracks are quite small and the 3m would cost about half the price of a new wheel. Don
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I used POR15 Epoxy putty, but they are probably all very similar. Do not use an etch primer (do not use anything with acid) if you use epoxy....the paint will end up bubbling and peeling/chipping off down the road.... the POR15 was fairly easy to sand once it had hardened...
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | I have also used 3M (bondo) bumper repair. It is a two part product for repairing bumper covers on new vehicles. What I like about it compared to other epoxy products is that it is flexible and black. Look for it on line in places like Walmart.com and Amazon.
| | | | | Joined: Feb 2015 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 16 | I use short strand fiberglass filler on tractor steering wheels and on my 57 wheel. Lots of sanding and shaping but very strong and no recracking so far. Not cheapest but permanent. I agree on the 30 hour comment. I used epoxy primer and epoxy topcoat from "Endura" best coating on planet similar to por15 only better.
GGE
