3 members (Wheelie, Ole49GMC, GMCJammer51), 98 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#1259551 03/21/2018 4:59 PM
I have a 48 with original bumpers front and rear. The previous owner had welded tow bar brackets to the front and when I removed them the bumper edge has a couple 1/4" chunks missing and the face has divots and missing metal. Should I try to have it repaired or just purchase a replacement? What might be the proper way to have it repaired. Any help would be great.
As they say, it depends. Chrome or painted? Show or just go? Have it done or do it yourself?
A good welder can easily patch and grind and fill for paint ready. If you want rechrome that's big $.
Most here say to avoid the aftermarket chrome the vendors sell, your choice but not cheap for iffy quality.
I prefer to reuse old parts, warts and all until you can't use them no more. Nice paint over old stock chrome is a good compromise unless you gotta have chrome.
NHluvstruck...
1951 3100 5-window
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
Sir Searchalot
Sir Searchalot
Depends on your budget and your level of condition you want, daily driver, better, better than that. Sounds like too far gone for me. Chucks of missing metal is doable but may be false economy. New or a donor, either way is good. new painted, no worry about chrome quality......$100. Good donor....free- $100
I believe the bumpers are spring steel, so welding on them removes the temper and strength. If there are chunks missing, I'd replace, even with repop instead of depending on a weakened bumper. My front bumper initially looked OK, with just a couple minor bends, but when I removed it, there were cracks around a couple of bolt holes. It's going in the scrap bin.
Mine (1951) sure didn't feel like plain stamped steel. I'll have to see how easy it bends and maybe do a grinder test for carbon content.
Sir Searchalot
Sir Searchalot
Kevin, My correction. Spring steel from at least 1945 into 60-66 era. Except big trucks had carbon steel.
I'm with you on the big truck bumpers, they're drawn so deep that there's no way they could be spring steel. Too expensive to fab from spring steel.
