| | | Forums66 Topics128,050 Posts1,055,683 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I have a 1956 235 from a belair. Going in my 1950 pickup with original 4 speed. Reusing the bell housing from old 216 so motor mounts will work and starter Questions 1- replaced the pilot bearing with a dorman 690-034. It just goes right in and spins around. I remember how hard it was to remove the old one. Should it be this loose?
2- how important is it to check the runout on bell hosing? Was hoping it is not too big of a deal as I don’t understand the shop manual about how to do it
3- does bell housing get lock washers on the mounting bolts?
Thanks in advance. | | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I guess I should have said pilot bushing | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | There are two different pilot bushings. If the engine was originally equipped with a Powerglide there is a special diameter bushing that converts it for use with a standard transmission. Be sure the starter and the flywheel match- - - -the 56 would have been equipped with a 12 volt starter, and the 216 would have used a 6 volt unit. There is a gear tooth mismatch between 6 and 12 volt starters and flywheels, although the 6 volt starter works OK on 12 volts. Just be sure the starter and flywheel come from the same vintage vehicle. Runout isn't usually an issue except where the fit between a Hydramatic trans and an engine block not originally mated to a hydramatic is involved. Jerry
| | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | Jerry I got the bushing that was for the conversion from power glide to standard. It seems to spin around when I install it. I’m thinking as long as it doesn’t move up and down I should be ok. What do others think. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | No more than what the bushings cost, I would get the other one and try it.ðŸ›
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As evac34 posted:
Dorman 690-034
"Only Used For Automatic Transmission Conversion; Powerglide to Manual Transmission; 1.060 In. O.D." | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The bushing needs to be a tight fit in the crankshaft. You might try to install it with green Loctite to take up the slack, but don't put things together until you get a good fit that doesn't move. Jerry
| | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | Maybe I’ll try the other bushing see what happens | | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | Ok got the other bushing that was available. Nice and tight fit The first had an OD of 1.06. New one OD 1.09
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | By 56 I am pretty sure the cranks were all drilled the same. The crank in my 261 is from a 56 powerglide motor. Used a pioneer PB-656-HD bronze bushing. Autogear, the company that makes all of the muncie parts and transmissions, sells a real oilite bronze bushing as part number 0-127-006. That one is exceptional quality.
Mike
