The 590474 casting was used from 1931 thru 1947.
The shifter levers are the same from 1929 thru 1947, so having a bent one just means the owner bent it to suit his needs.
The redish brown knob sounds like a 1937 passenger car accessory knob (black was standard issue).
Mike B
