1 members (ronsway),
185
Mod | | | Forums66 Topics128,167 Posts1,057,019 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 48 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 48 | I have an interesting block.
The casting number ends in -5911 which is indicative of a late '53- early '54 235. It is wearing a CAR bellhousing and a a smaller clutch assembly. It is a higher-pressure 235 with NO Tenneco sign-shaped oil plate, has the old high water pump of a 216, and had a -5913 head with the 4 valve cover screws. It was originally painted honest-to-goodness BLUE... not grey, not light blue, not orange etc. That blue still shows on the block in places. The original valve cover is here too and it is the later 235 type.
The engine serial number is kind of indistinct (poorly stamped) but it appears to be
0996855 F5
Vinbuster returns this as a 235 built in.... 1960 , no less, in Norwood OH.
An old-style water pump block THAT late???
Replacement engine, or dare I say... Corvette? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Post the castings codes, date codes, and engine serial number (a photo of this, if you can).Most likely that block has solid/mechanical lifters? 0996855 F5 -- does not match the format of Engine Serial Number sequences in Specification Manuals. Let's see a photo - maybe it has been added/changed? You info is correct regarding the date range of the block/head (1953-55 Corvette 235 and various car/truck 1954/55 235). Casting & Date codes will confirm a lot of speculation. | | | | | Joined: Oct 2008 Posts: 48 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 48 | UPDATE: The engine # on the tab by the distributor is:
0996855 F54Z
Missed those other characters when looking in bad light conditions. I re-ran it in the Vinbuster and it came back the same result...
BTW tclederman, I still cannot access your site! I finally figured out that the browser and security was the problem that kept me off here for a good while, but your site still won't load either.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | F54Z Regular car 235 engine (mechanical lifters) http://www.1954advance-design.com/chev-specs/1954-c-ser.jpgMy website is wide open - no security and no encoding. Simple html standards. Your security software may not allow access to standard html websites. | | | | | Joined: Oct 2008 Posts: 48 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 48 | I can access tclederman's site with my mobile but not with Firefox on a PC.
Still checking on the particulars of this block. I want to rebuild it unless I can find an early 261 of the similar design. I could do the plate to relocate the low water pump on later models but I really want to to make this thing look more "original".
BTW I didn't really originate this thread, I somehow tried to reply to an older thread by this name and got "credited" as a new thread starter. I knew this engine was definitely not dated as a '49 from the get-go.
