1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Have installed the side window rubber scrappers in Sparky. What a royal pain! They do not fit! Need to try a different part supplier. Recommendations will be appreciated.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | I would be interested in knowing what the issue is/was, and the solution. I will be doing this area of my 41 this season (hopefully).
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | The rubber scrapes/sweeps fit so tight against the window glass and glass frame raising or lowering the glass is near impossible. The rubber is seated in the door panel and door channels correctly. It is a real hassle to install them and a real bummer when after all that struggle, to discover the effort was in vain! Had I thought to search here in the Stovebolt beforehand I might have avoided this problem. There was a long thread discussion in 2015 in the Stovebolt about problems the Advanced Design Truck guys were having with product differences. Apparently, the vendors offer different width rubber products. I have heard from two other ‘46 truck owners that used Jim Carter’s sweeps with success. I have ordered some from them and will give them a try. | | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | I just got done installing window seals and glass in my '36. The set I got from Chevs of the 40s (a Steele product) are WAY to big, as if they are for trucks from the 70's or something. The ones I got from Jim Carter's Oldchevytrucks.com are the correct smaller ones for your 1946!
Daryl
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Yes, that is what I discovered after talking to a couple other guys that experience the same headache. I intended to update the progress on that task. The JC product also fit in the channel a bit easier as well. Seems like for some rubber items Steele is the go to vendor and for others not so much. | | |
