1 members (mason86),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | I need to move an inop vehicle around in my shop. It weighs ~5000lbs. I have smooth concrete floors. What brand or model of tire skates/dollies have you had success with?? I looked at HF but I'm always a little queasy with their quality. Thanks for any info you can throw my way.
SimS | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | I have 4 of these (two sets). They're fairly robust, I haven't had my 3600 on them which I believe is in the 5k range, but they worked very well under the Duster (about 3,200 lbs.). I wouldn't hesitate to use them on a 5k vehicle. Moving a vehicle around is a breeze with a set wheel dollies and the first time I used them, I kicked myself for not buying a set much earlier. Sure beat tugging and pushing a rig on two floor jacks.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The key to usable skates is the quality of wheels. I bought a second hand set which originally came from HF and the axles were not centered in the cast wheels, and the swivels where unresponsive when a completed vehicle was used. I don't know anything about what HF is selling today. Maybe they are better than what I had from several years ago.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | My first pair of HF dollies has cast wheels, the second pair have rubber. If I had known they were rubber while still in the store I wouldn't have gotten them, but they do work. Mike B  | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have 4 of these. https://www.otctools.com/products/1500-lb-easy-roller%E2%84%A2 It is quite often that I have to move my projects to make room for my line haul trucks. I have had them for several years and figure they were worth every penny I paid for them.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 3 pieces of water pipe work well for me.
Ed
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I have four of these and like them very much. They do double duty for me. One is to move vehicles around. The other is to remove/install the wheels when doing a brake job or rotating tires. Pump the pedal, line up the studs, then slide the wheel on to the drum or rotor. Sure saves the back, particularly with big truck wheels. www.harborfreight.com/1250-lb-Capacity-Vehicle-Positioning-Wheel-Dolly-61917.htmlI recently had a '57 GMC one ton panel in the garage. These dollies made it easy to move around by myself. If you buy them, HF has more than one model number, just as they do with many items. Different model numbers means different manufacturers. There are small differences. Try to find four with the same numbers to get a matching set. Matt | | | | | Joined: Nov 2004 Posts: 2,402 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,402 | I have a couple sets of the HF furniture dolly's ($9.99 on sale). They work, but not very well. It takes way too much effort.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I just bought a pair from HF. They seem well made for what they are. I don’t see any difference in quality than the Big Red or OTC that you would buy at the other big box stores.
I’ll tell you how well they work when I clean the shop out. LOL.
I do like the idea of the hydraulic lift ones. You can lift, move, set back down. The price seems a little prohibitive.
What are you moving that’s 5000 lbs? | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | What are you moving that’s 5000 lbs? I'm moving a Toyota Land Cruiser FJ60 to make room to work on my Chevy C60. They both need a new clutch and the C60 goes first. Given the sketchy reviews on the HF units and the $$$$ for the GoJacks I'm almost tempted to make a set with known quality casters. In the meantime I'm scouring the local CL for any deals that may pop up. SimS | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The local home improvement stores sell steel and urethane casters. They are a little pricey and I'm not any more confident in them than the HF units.
If you're looking on CL, I've seen scaffold casters used to to move vehicles around before.
