| | | Forums66 Topics128,053 Posts1,055,778 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I have decided to do a cheap repaint on the truck. I plan on painting over existing paint after scuffing it up a bit. What is the best/easiest filler to use on small scratches and very minor imperfections? I don't want to go down to bare metal.
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Regular body filler like evercoat's rage should not be applied over paint. For your app of smoothing minor dings and scratches the best product to use is a poly glaze product. Evercoat's metal glaze or Upol's dolphin glaze. A poly glaze product is different from regular fillers is that the filler material(talc) is ground up finer. They are a thinner product that is designed to be applied over sanded paint to fill minor surface imperfections | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 |
Blue 50
