4 members (TooMany2count, Wally / Montana, Phak1, 1 invisible), 72 guests, and 3 robots.
Topics128,139
Posts1,056,754
Members48,454
In the 1947-54 Chevrolet Truck Factory Assembly Manual
Section 2, Sheet 2.00 thru 2.03
Under "Frame Checking Instruction"
Looking at the frame side view it says 3° degrees, 42' 9", CL (center line) of Crankshaft.
3° degrees means engine pitch.
What does the numbers 42' 9" mean?
All models show the same numbers 42' 9" .
Check attached picture for reference.
xfiles
Insomniac
Insomniac
3 degrees, 42 minutes, 9 seconds. Very precise angle!
Gord 🇨🇦
1954 1/2 ton 235 4 speed
OK Thanks,
You could say the engine is angled down in the rear by 3.7025°degrees, expressed as a decimal number
That is just a little under 3 3/4° degrees.
Angle Measurement: Degrees, Minutes, Seconds
Calculators on lower part of page.
Attacked: Engine &Trans. Pitch
xfiles
