5 members (cmayna, 3B, Leo, 39Master85, Otto Skorzeny), 87 guests, and 1 robot.
Topics128,075
Posts1,056,279
Members48,441
#1256937 03/01/2018 2:44 PM
I have a 1949 3600 with a SM 420 4 speed transmission.
How much gear oil does it take? Should it be filled to the fill hole?
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
With the vehicle parked on a level floor the oil should come to the bottom of the fill hole. That places the level just below the centerline of the input/output shafts and prevents leakage out of either end. The rotation of the gears (especially the big bull gear for 1st.) circulates the lube inside the case.
24601
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
For checking the fluid level: "With unit/transmission at operating temperature the lubricant should be level with the bottom of the filler plug hole [on the side of the transmission]."
"If the lubricant level is checked with the unit/transmission cold, the lubricant level should be 1/2" below the filler plug hole [on the side of the transmission]."
If you are filling a warm transmission after draining (many people do that, thinking/hoping the thinner oil will drain out better), use your judgement - I still fill to about 1/2 in below the filler hole on the side of the transmission, and then drive it and then check it after the drive.
C Online: Content
I stick my index finger in the hole, then slightly bend the finger downward then back up. Check it. If I find some oil on the tip of my index finger, I'm good......well the truck is good. I find that filling it til it runs out the fill hole is just a little too much oil.
Craig
