3 members (DadsFirstPickup, Hotrod Lincoln, Gib70), 103 guests, and 3 robots.
Topics128,089
Posts1,056,366
Members48,442
#1256424 02/26/2018 12:53 AM
The title says it all. I have a 3100, but found a guy claiming to have a 3600 bed. Does anyone know if the bed sides, gate, front panel were the same '47-'53? Mine is a '51 and he says it's a '50...
bigBob,
The 47 and 48, had the gas tank mounted between the frame rails, behind the cab. The fuel filler neck, came out the right side of the bed. Starting in 1949, they mounted the gas tank, in the cab, behind the seat. That continued at least through the early 55 AD. However, the 54 and 55, have a different bed, than the 47-53. You probably already are aware of this. In the event that you are not, the 3100, has a short bed. The 3600 and 3800, both have a long bed. The wheel base, on a 3600 and 3800, are about 9 inches longer than your 3100. That would be a major undertaking to convert yours. To fully answer your question. The tailgate and the front panel should all be the same for 47-53.
In the event that you are just not able to find used 3100 bed that meets your expectations, you might take a look at Mar-K, They manufacture a really nice reproduction bed. They even use one of the original tailgate stamps, from one of the old factories. My original bed was beat. So, I purchased one from them. Everything looks right and it fits right. Just something to think about.
Hope this helps. Good luck with your restoration.
Rugo
Steve Rugg
53 3100
The 3600 beds are longer than that of the 3100.
The front panel, tailgate, fenders are the same. up till 53.
Some good dimensions here.
http://chevy.oldcarmanualproject.com/
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
You can cut 9 inches off of the front of the 3600 bedsides to make it fit. I don't think that I could bring myself to cut them because I don't know if anyone makes reproduction 3600 bedsides.
Insomniac
Insomniac
Yes, I cut down long box bed sides to make a short box. I drilled out the spot welds on the stake pockets so they could be reused. The middle stake pocket was removed and the hole patched. It was a lot of work. If I lived in the US, I would consider buying new parts from Mar-K. Since I'm retired, I have the time to mess with these things...
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks for the info! The guy sold before I could get to it. I couldn't bring myself to cut up old iron like that any ways. Cheers!
