0 members (), 59 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1255344 02/17/2018 9:20 PM
I read a lot of the old posts about plugs. My 1956. 235 used R44 spark plugs. No longer available what is everyone using for that motor today??
evac34 #1255349 02/17/2018 9:39 PM
There might not be a need for resistor plugs.
Do you have a radio? 6v/12?
What plugs are you using now? Do they produce interference with other devices (cell phones, maybe)?
The original was AC 44-5 plug
http://www.sparkplug-crossreference.com/convert/AC_DELCO/44-5
http://www.sparkplug-crossreference.com/convert/CHAMP_PN/RH8C
evac34 #1255354 02/17/2018 10:42 PM
AC R45, available from Rockauto.
evac34 #1255371 02/18/2018 12:49 AM
Rj12yc is the Champion resister (the old number was rj12y). You can also use a rj14yc if you think a slightly hotter plug is needed. The non resistor is j12yc and j14yc.
Mike
evac34 #1255392 02/18/2018 2:06 AM
The plugs I took out of motor was AC44. They were in motor when I got it
evac34 #1255394 02/18/2018 2:30 AM
If my memory serves me correctly there was AC43, 44, 45, 46. All interchangeable, with the 43 being the coldest to the 46 being the hottest. Any good parts store can get you spark plugs for a Stovebolt 6. If you are going for a concourse restoration you can get new old stock through eBay or the automotive swap meets.🛠
evac34 #1255400 02/18/2018 3:57 AM
8
8 Offline
I use AC R44SX. They are what Tom Langdon recommended with the HEI distributor.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
