0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
Got a 302 head casting no. 2193983 with a date of NE 292. Can’t identify that date no. Any help on this number?
50sChevys
I think the 2193983 head was the only one ever used. Does the date really make a difference?
Well, I have it wrapped in a protective covering to keep moisture out, which I can undo it if necessary. However, it’s in the same spot as my other 302 head which is a 2193983 and date code of D154.
Wondering if it is a Canadian produced head or off a military produced head.
50sChevys
Just my curiosity of it not following the normal date code format as we know it.
50sChevys
Join the oldGMCtrucks.com discussion board and ask the question there. Try to post a photo of the code.
OK , will do.
50sChevys
Crusing in the Passing Lane
There are 4 different 302 heads, many require separate Pistons, two have larger ports(desireable), I will look in my files. Patric's catalogue spells them out.
Ed
Tim,
Thanks, there is the info.
Ed
[IMG]http://pic100.picturetrail.com/VOL424/525201/24799545/413778868.jpg[/IMG]
OK, here’s the real story on the date code on this head. The NE292 code means this... the ‘N’ means it’s a military built head which has a higher NICHOL content than the civilian built head and the deck is .010 of an inch higher. The E 292 is May 29, 1952.
50sChevys
Nice to know. I wonder if the compression ratio is the same or Not?
Ed
Only differences mentioned and said it was,quote, “the best of the best”...
Glad to hear it since I have one and a newly rebuilt valve train for it. Hope I never need it! Lol
50sChevys
I also have one attached to a block.
Ed
