0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 12 New Guy | | New Guy Joined: Feb 2006 Posts: 12 | Got a 302 head casting no. 2193983 with a date of NE 292. Can’t identify that date no. Any help on this number?
50sChevys
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think the 2193983 head was the only one ever used. Does the date really make a difference? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2006 Posts: 12 New Guy | | New Guy Joined: Feb 2006 Posts: 12 | Well, I have it wrapped in a protective covering to keep moisture out, which I can undo it if necessary. However, it’s in the same spot as my other 302 head which is a 2193983 and date code of D154.
Wondering if it is a Canadian produced head or off a military produced head.
50sChevys
| | | | | Joined: Feb 2006 Posts: 12 New Guy | | New Guy Joined: Feb 2006 Posts: 12 | Just my curiosity of it not following the normal date code format as we know it.
50sChevys
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Join the oldGMCtrucks.com discussion board and ask the question there. Try to post a photo of the code. | | | | | Joined: Feb 2006 Posts: 12 New Guy | | New Guy Joined: Feb 2006 Posts: 12 |
50sChevys
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There are 4 different 302 heads, many require separate Pistons, two have larger ports(desireable), I will look in my files. Patric's catalogue spells them out.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Tim, Thanks, there is the info.
Ed
| | | | | Joined: Feb 2006 Posts: 12 New Guy | | New Guy Joined: Feb 2006 Posts: 12 | [IMG] http://pic100.picturetrail.com/VOL424/525201/24799545/413778868.jpg[/IMG] OK, here’s the real story on the date code on this head. The NE292 code means this... the ‘N’ means it’s a military built head which has a higher NICHOL content than the civilian built head and the deck is .010 of an inch higher. The E 292 is May 29, 1952.
50sChevys
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Nice to know. I wonder if the compression ratio is the same or Not?
Ed
| | | | | Joined: Feb 2006 Posts: 12 New Guy | | New Guy Joined: Feb 2006 Posts: 12 | Only differences mentioned and said it was,quote, “the best of the best”...
Glad to hear it since I have one and a newly rebuilt valve train for it. Hope I never need it! Lol
50sChevys
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I also have one attached to a block.
Ed
