11 members (Woodcmiami, Hotrod Lincoln, WICruiser, KCMongo, TexasJim50, Bill Hanlon, MNSmith, Chip O, LAROKE, Southerntruck, 1 invisible), 72 guests, and 3 robots.
Topics128,032
Posts1,055,523
Members48,425
#125491 04/11/2007 6:13 PM
Hello, I have a 53 3800 1T. He needs a right rear corner post (cant find) and cab corners (cant find) can you help me find those? Also, Thing has these 1" to 1.5" diameter holes in his bed. 3 of them and then smaller misc. sized holes. How do I fix those? I dont want to "bondo", any suggestions? Also, on top of his head (cab) is like a chunk missing. Roughly 1/16" deep and about 8" in diameter (not dented). How do I fix THAT? Thanks guys!
Chey
LOST1953
My favorite color is CHROME
The ugliest trucks are driven by the prettiest girls wink
I dont suffer from insanity, I enjoy it!
O Lord, WHY did I buy another "Thing"? (again??)
1953 Chevy 3800 1-ton Gallery
More photos at MSN
#125492 04/11/2007 6:36 PM
Anonymous
Unregistered
Anonymous
Unregistered
The patch panels should be the same as those for a 1/2 ton. The cab corners can be found at any of the suppliers and the lower rear "B" pillar posts are also commonly available. Check ClassicParts.com.
Where are the holes in the bed located? On the sides, front panel? If the holes are located on a flat surface you can cut a patch from some similar gauge/thickness sheetmetal and weld it in place.
Is the roof a hole or a dent? If a dent it can be pulled out by welding a nail to the surface and "pulling" it out with a slide hammer. It might take some body filler to smooth out the minor issues left. If it is a hole then you can bend some sheetmetal to match the contour and weld it in place but be careful not to warp the metal as that area will not take too much heat at one time without bending out of shape.
If you do not have a welder you can rent them from some of the home improvement places.
good luck
#125493 04/26/2007 2:58 AM
I got everything but a panel for the side of the bed, and a "cover" to repair the top of the cab...Thanks for the help!
Chey
LOST1953
More photos at MSN
