| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | Hello, I have a 53 3800 1T. He needs a right rear corner post (cant find) and cab corners (cant find) can you help me find those? Also, Thing has these 1" to 1.5" diameter holes in his bed. 3 of them and then smaller misc. sized holes. How do I fix those? I dont want to "bondo", any suggestions? Also, on top of his head (cab) is like a chunk missing. Roughly 1/16" deep and about 8" in diameter (not dented). How do I fix THAT? Thanks guys!
Chey LOST1953 My favorite color is CHROME The ugliest trucks are driven by the prettiest girls  I dont suffer from insanity, I enjoy it! O Lord, WHY did I buy another "Thing"? (again??) ---- 1953 Chevy 3800 1-ton Gallery More photos at MSN ----
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | The patch panels should be the same as those for a 1/2 ton. The cab corners can be found at any of the suppliers and the lower rear "B" pillar posts are also commonly available. Check ClassicParts.com.
Where are the holes in the bed located? On the sides, front panel? If the holes are located on a flat surface you can cut a patch from some similar gauge/thickness sheetmetal and weld it in place.
Is the roof a hole or a dent? If a dent it can be pulled out by welding a nail to the surface and "pulling" it out with a slide hammer. It might take some body filler to smooth out the minor issues left. If it is a hole then you can bend some sheetmetal to match the contour and weld it in place but be careful not to warp the metal as that area will not take too much heat at one time without bending out of shape.
If you do not have a welder you can rent them from some of the home improvement places.
good luck | | | | | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | I got everything but a panel for the side of the bed, and a "cover" to repair the top of the cab...Thanks for the help!
