7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | Im restoring 55 chevy 3600, and have had to repair a lot of rust, floor pan, lower door hinge, inner step, patches in fenders, bottom of doors, lower 24" of ourter door skin and lower section of bedsides. I have become very good at this and at shrinking metal expesialy the bedsides inorder to remove the waves. All patch welds were butt welds and I used a light source behind the weld to help identify and fill the pin holes. My questions is this. I plan on painting the back side of the welds with eastwood encapsalting paint the brushing over this with seam seal to insure I have sealed all pin holes, is this the best approach or would any one recommend somthing else instead?
thanks | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | You could use a good brand of auto body Premium filler then epoxy prime both sides of the panel. You can still use filler over the eproxy primer if required. The eproxy primer is the best in my painting book because it has an excellant grip to the metal and will go over or under filler and is a excellant moisture barrier as well as many other reasons.
34 & 35 trucks are the greatest
| | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | POR-15 products work well for this, too. That's what I used. They have a steel reinforcing fabric that you can lay down and then coat with POR-15. When it hardens, you can drill through it. Makes a nice seal before painting. It's been a few years since I did this, but I think I described it right. I've used most of their products with good success, Marine Clean, Metal Ready, putty and their enamels. You might want to check them out. | | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | Thanks for the posts, I planed on the epoxy and well most likely go that way. If you bondo over the epoxy do you need to sand it first and if so what grit
thanks again | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Use a Scotch Brite pad to rough up the epoxy surface.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | if you use a good encapsulating type paint, be it Por 15 or the eastwood product they will seal. they need to contact the metal NOT a filler that's why they are what they are. the filler applies over the encapsulator paint only after it (painted surface) has been preped to accept anything other than the base protector paint.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
