0 members (),
256
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 40 | Hello We installed a new under bed gas tank from early classic enterprises on my 65 short step I was told the sending unit on a 60-66 should be 30 ohm I believe the gauge is original on the 65, were all 65 gauges 30 ohm? Currently the tank Is about half full but the gauge is reading full
Any opinions? Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy stovebolt409, I believe the sending unit/gauge ohms for 1965 is 0-90 ohms. They changed the ohms sometime in the early/mid 60s, but I can't recall for sure what year the change took place, hope that helps. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | 409, you need to change the resistor on the sending unit to a 0-90 , Vincent Mayeda in CA. does the conversion (you send him your sending unit and he changes the resistor), he's on FB so you can look him up that way. Mayeda Motor Sports. | | |
