1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#125250 03/27/2007 4:51 PM
Does anyone know if it is possible mount a 41 rear ) window (pot metal outer frame) to a 46 cab?
#125251 03/27/2007 10:32 PM
I don't see why not, the cabs are the same. Just make sure the holes line up.
I'm not exactly sure, just an educated guess.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#125252 03/28/2007 2:22 PM
That is my thought also, I am getting ready to pull the window out of the 41 amd see. Thanks for the reply.
#125253 05/18/2007 9:11 PM
The cabs are the same, the 41 has a metal innner cab panel that is also drilled and the outter ring holds the inner panel. Also make sure you get the rear rubber the right way around or you'll have leaks. Just did the window on my 42 with a 41
Keith and Kim
1942 Chev 3/4-Ton Flatdeck in the Gallery
Victoria, BC, Canada
#125254 05/19/2007 12:12 AM
Be real careful, that diecast frame is easly broken. It wont bend much at all.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#125255 07/02/2007 3:29 AM
Thanks for the input.....
