| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | Does anyone know if it is possible mount a 41 rear ) window (pot metal outer frame) to a 46 cab? | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I don't see why not, the cabs are the same. Just make sure the holes line up. I'm not exactly sure, just an educated guess. | | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | That is my thought also, I am getting ready to pull the window out of the 41 amd see. Thanks for the reply. | | | | | Joined: Jan 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 63 | The cabs are the same, the 41 has a metal innner cab panel that is also drilled and the outter ring holds the inner panel. Also make sure you get the rear rubber the right way around or you'll have leaks. Just did the window on my 42 with a 41 | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Be real careful, that diecast frame is easly broken. It wont bend much at all. | | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | Thanks for the input..... | | |
