| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 24 New Guy | | New Guy Joined: Jan 2017 Posts: 24 | I'm working on a clutch replacement and the pilot bearing in the clutch kit appears to be bigger than the old one. The old one is cracked and bad shape, it measures 1.04 O.D. and the new one measures 1.09. It appears that a standard size was used for many years, but the new one doesn't want to go in, do I just need a bigger hammer? I'm not sure how tight of a fit it should be.
For further info if needed, I've got a 235 out of a 53' Bel air in a 46' 1/2 ton with a 3 speed. Thanks for any insight. | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Did your '53 235 come out of a Belair with a Powerglide?
If so, the '53 235 car engine with a Powerglide did not come with a pilot bushing. The crank for that particular year engine with the Powerglide is an oddball in that it is the only year/tranny combo for a later model 235 that will not accept a 'normal' pilot bushing. The good news is that the crank will accept the slightly-smaller-than-normal pilot bushing that has the correct ID for a manual transmission input shaft. They are available, just takes some research. I picked one up a few months ago at either Autozone or O'reilly, not sure which one. I think it was a Dorman part number. I'll see if I can find the number.
Matt | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is it, Maybellene Inside Diameter (in): 0.593 In. Outside Diameter (In): 1.06 In. 1950-1967 Powerglide-equipped Chevrolets https://www.dormanproducts.com/p-18310-690-034.aspx | | | | | Joined: Jan 2017 Posts: 24 New Guy | | New Guy Joined: Jan 2017 Posts: 24 | Yes, it is a power glide. I knew something wasn’t adding up. Thanks for the info, it saved me a bit of research, now I don’t have to go looking at the O.D. of all the different options out there and can get back to work. Thanks! | | | | | Joined: Jan 2017 Posts: 24 New Guy | | New Guy Joined: Jan 2017 Posts: 24 | Ok gentlemen, the dorman 690-034 is still too big. Does it need a little persuasion? Are there other options or does it need machined? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Put it in the freezer for a few hours and try it again.ðŸ›
