1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | Looking for input on tube shocks - front and back- for a 49-3100 stock suspension and 15" wheels. Front shocks have been converted to tube type and angle forward about 15-20 degree. I would appreciate make and part numbers. Thanks
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | you already have front tube type shocks? There should be a part # on them. You may need to clean them off but it is normally near the bottom of the tube. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | 1950 used tube shocks, you should be able to get P/Ns on line or at flaps. Maybe can find brackets to convert to tube shocks from one of the classic truck businesses.
Ed
