| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | I need clarification on the number of notched cross sills for a 1947 AD 3100. My box had the incorrect cross sills and I suspect even the incorrect box. The under frame gas tank nozzle seems to have been carved out to fit the filler tube. Sooooooo, I want to be sure I have the correct information for my rebuild. Conflicting info has me understanding the half ton had only one notched cross sill for over the gas tank. The long bed option and the bed of the 3/4 ton from 1947 BOTH required TWO notched cross sill? I’ve ordered one notched sill but now question whether or not I may require TWO.
Can anyone help me out on this so I don’t make a stupid error? Don’t want to appear even more silly than I am! ;-) | | | | | Joined: May 2015 Posts: 11,130 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,130 | Per Mar-K's site, there's only one needed. PN 10009
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | I know we checked a short bed needs one notched sill, but I don't have reliable information for a long bed 3/4 ton. Our site does not indicate a notched cross sill for 47 Chevy long bed. Hopefully someone who has an original 3/4 ton long bed with under bed tank will chime in. I would like to get it right.
Mar-Ktech | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | I found a photo of a 48 long bed sent to us by a customer. Everything appears original, unrestored. No wood in the bed it shows the tank under the bed with no notched cross sill. Short bed definitely needs one notched cross sill, the second one back from the cab. Hope this helps.
Mar-Ktech | | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | That’s what I found for my application, one notched for short bed. Great news for me, the notched cross sill I purchased will do the deed. Looks like my bed front and first cross member will likely need replacement doe to rust and the patch of the PO. Thanks for your input. Now to get on the phone to order....... | | |
