| | | Forums66 Topics128,056 Posts1,055,800 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2017 Posts: 36 | So I just pulled out the 283 engine from the 56 3100 and in trying to pin down the 283 exactly looks like it was used 2 years before it was built! Date casting F 11 2 should be June 11 1962 block casting 3789935 61-62 car or truck and some listings show it used to 1964. 170-315 HP The engine stamp code is F0612D . That translates to Flint June ,12 which matches the block casting date of June 11 . The D is a mystery as it is shown as either a 1958 283 with Power Glide or a 1960 283 with Power Glide . That means it was used in 1960 2 years before it was born?. . Looked at several different listings for date codes and all agree 1960 PG. I must be missing something, or it went through a time warp. back in time a couple years. Does not look to have been machined off and re stamped. Engine doesn't look like it has ever been apart. | | | | | Joined: Sep 2017 Posts: 135 Shop Shark | | Shop Shark Joined: Sep 2017 Posts: 135 | The D goes from 1958 to 1964 on the list that I'm looking at. All with powerglides. http://www.1968ss.com/sbcsuffix.asp
| | | | | Joined: Sep 2017 Posts: 135 Shop Shark | | Shop Shark Joined: Sep 2017 Posts: 135 | My engine is F0508MA 3789935 E42, so pretty close on engine numbers. | | |
