8 members (carbking, 3B, msmall, Bill Hanlon, FrankenChevy, walter74, Stovebolt48, Shardean),
58
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | has anyone used lead-no-lead body filler out there?from (eastwood). problems,concerns how will it affect paint?
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | Are you asking about lead filler or solder?
| | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | lead filler "old school body work". eastwood has come out with alternative no lead filler , apperantly it is just like old school lead body work ,except no lead and you can power sand it . videos show it applys like lead filler. I have used plastics in the past, decades ago. that hurt to type! but personal choice metal body/ metal filler."the old lead sled" . SO if its a good safe metal product . that can be finished like "bondo" . win win ! | | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | I was mistaken it is lead solder . just left eastwoods site in the bodyfiller section so lead no lead solder is what I'm hoping someone can give advice about | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Good grief- - - -that price is ridiculous! I'll bet it doesn't stick or work as well as the real stuff, either! PPG used to sell a powdered product that we mixed with a resin resembling clear lacquer called "Aluma-Lead" that worked very well, but that was over 40 years ago. I doubt if it's available any more. Jerry
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | Good grief- - - -that price is ridiculous! X2. But the kit does include a few tools like paddles and files. But you can get 3 lb of lead-free solder at about any plumbing supply house for way less than that. It's been around for over 10 years in the plumbing business. Generally a tin-silver or tin-silver-copper alloy. It's available in wire or bar form. Works just as well as Lead-tin solder for sweating pipes and could be used for body work as well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | yes this is it. price is a little steep belive its the hey stupid this is what you need and we will put it in a box for you price. individual prices look reasonable. | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Hello All, I went down this road a few years ago and purchased this product from Eastwood. I wish I could say it was awesome. Watched all the videos also. But it's not a easy to work with as "Lead". It has a very small melt window, and you could end up having a lot on you shoes real fast. Not easy to touch up either. Also if the "Tin" process isn't perfect it's a bear to clean up the sub straight.
Just my 2 cents
Clem 59 Chevy 3600 New Hampshire
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | We used to tin panels with a very thin wipe of acid core solder, followed by dabs of bar solder that had been softened with a feathery acetyline flame. There's definitely a learning curve involved in softening up the lead just enough to spread it around with a hardwood paddle. Keep the paddle slightly slippery with motor oil on a rag to keep it from sticking to the lead. Jerry
| | | | | Joined: Dec 2017 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 51 | I pulled the trigger bought the kit. after the 4th body shop or 2 restro . shops buy fiberglass fenders or $2800 - 4000 and be as much bondo as metal neither is acepticle so ill see what I can do.long long way from paint but I will let u all know .any tips / help would be appreciated. | | |
