3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
#1250014 01/08/2018 5:03 AM
Fox
Offline
Wiring up my truck and will be updating with fuses. I'm looking at some generic fuse boxes and my question is this:
Has anyone modified the voltage regulator box to hide a fuse box? It would sure look nice and stock (apart from my ugly alternator).
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Y
Y Offline
I haven't used a regulator box but I did modify the extra large fusebox from a bog truck one time.
FYI, you can always spend the big bucks and get the alternator that looks like a stock generator.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Y
yar Offline
Y Offline
Robert,
Do you know Bob Hayden over in Sonora?
Ray
Fox, yes, I modified a voltage regulator box and turned it into a fuse box to house all the fuses for the TBI system I put on my 327. Modified VR Box (My 48 is pretty much externally stock but otherwise I’ve made quite a few changes.) I also run another fuse block up under the dash above the e-brake for everything else.
Fox, I’ve enjoyed watching your build: keep up the good work!
H Online: Content
When you do that, modify the cover to use Dzus fasteners instead of attaching screws. Then you can remove the cover with just 1/4 turn of the fasteners with a screwdriver.
Fox
Offline
Nice.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Y
Y Offline
Yar,
Not sure that I do? Got a picture of his truck?
Robert
55.1 GMC 450 COE
51ish GMC Suburban
8
8 Offline
I did just that when I rewired the '51 about 18 years ago. I don't remember exactly what I did, but I can get you a few pics if it will help.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
H Online: Content
I'd suggest replacing the metal bottom of the regulator housing with something non-conductive like Bakelite to minimize the risk of getting a short circuit. Leave a small metal perimeter and attach the phenolic bottom to it with rivets or sheet metal screws. Then mount the fuse block to that piece.
