1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Wiring up my truck and will be updating with fuses. I'm looking at some generic fuse boxes and my question is this:
Has anyone modified the voltage regulator box to hide a fuse box? It would sure look nice and stock (apart from my ugly alternator). | | | | | Joined: Aug 2003 Posts: 106 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 106 | I haven't used a regulator box but I did modify the extra large fusebox from a bog truck one time.
FYI, you can always spend the big bucks and get the alternator that looks like a stock generator.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert 55.1 GMC 450 COE 51ish GMC Suburban | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Robert,
Do you know Bob Hayden over in Sonora?
Ray
| | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Fox, yes, I modified a voltage regulator box and turned it into a fuse box to house all the fuses for the TBI system I put on my 327. Modified VR Box (My 48 is pretty much externally stock but otherwise I’ve made quite a few changes.) I also run another fuse block up under the dash above the e-brake for everything else. Fox, I’ve enjoyed watching your build: keep up the good work! | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | When you do that, modify the cover to use Dzus fasteners instead of attaching screws. Then you can remove the cover with just 1/4 turn of the fasteners with a screwdriver. Jerry
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | | | | Joined: Aug 2003 Posts: 106 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 106 | Yar,
Not sure that I do? Got a picture of his truck?
Robert 55.1 GMC 450 COE 51ish GMC Suburban | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I did just that when I rewired the '51 about 18 years ago. I don't remember exactly what I did, but I can get you a few pics if it will help.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | I'd suggest replacing the metal bottom of the regulator housing with something non-conductive like Bakelite to minimize the risk of getting a short circuit. Leave a small metal perimeter and attach the phenolic bottom to it with rivets or sheet metal screws. Then mount the fuse block to that piece. Jerry
