4 members (gswbbc, 32Fordpuchoptop, dwreills, Otto Skorzeny), 77 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#1248126 12/25/2017 12:44 PM
has anyone used lead-no-lead body filler out there?from (eastwood). problems,concerns how will it affect paint?
coolwhip #1248948 12/31/2017 8:52 PM
Are you asking about lead filler or solder?
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
coolwhip #1248981 01/01/2018 12:30 AM
lead filler "old school body work". eastwood has come out with alternative no lead filler , apperantly it is just like old school lead body work ,except no lead and you can power sand it . videos show it applys like lead filler. I have used plastics in the past, decades ago. that hurt to type! but personal choice metal body/ metal filler."the old lead sled" . SO if its a good safe metal product . that can be finished like "bondo" . win win !
coolwhip #1249885 01/07/2018 1:59 PM
I was mistaken it is lead solder . just left eastwoods site in the bodyfiller section so lead no lead solder is what I'm hoping someone can give advice about
coolwhip #1249887 01/07/2018 2:13 PM
Is this product you are referring to?
If not, please post a link to the product.
coolwhip #1249960 01/07/2018 10:04 PM
Good grief- - - -that price is ridiculous! I'll bet it doesn't stick or work as well as the real stuff, either! PPG used to sell a powdered product that we mixed with a resin resembling clear lacquer called "Aluma-Lead" that worked very well, but that was over 40 years ago. I doubt if it's available any more.
X2. But the kit does include a few tools like paddles and files. But you can get 3 lb of lead-free solder at about any plumbing supply house for way less than that. It's been around for over 10 years in the plumbing business. Generally a tin-silver or tin-silver-copper alloy. It's available in wire or bar form. Works just as well as Lead-tin solder for sweating pipes and could be used for body work as well.
yes this is it. price is a little steep belive its the hey stupid this is what you need and we will put it in a box for you price. individual prices look reasonable.
coolwhip #1250847 01/14/2018 1:08 AM
Hello All,
I went down this road a few years ago and purchased this product from Eastwood. I wish I could say it was awesome. Watched all the videos also. But it's not a easy to work with as "Lead". It has a very small melt window, and you could end up having a lot on you shoes real fast. Not easy to touch up either. Also if the "Tin" process isn't perfect it's a bear to clean up the sub straight.
Just my 2 cents
Clem
59 Chevy 3600
New Hampshire
coolwhip #1250855 01/14/2018 1:38 AM
We used to tin panels with a very thin wipe of acid core solder, followed by dabs of bar solder that had been softened with a feathery acetyline flame. There's definitely a learning curve involved in softening up the lead just enough to spread it around with a hardwood paddle. Keep the paddle slightly slippery with motor oil on a rag to keep it from sticking to the lead.
coolwhip #1251134 01/16/2018 2:54 AM
I pulled the trigger bought the kit. after the 4th body shop or 2 restro . shops buy fiberglass fenders or $2800 - 4000 and be as much bondo as metal neither is acepticle so ill see what I can do.long long way from paint but I will let u all know .any tips / help would be appreciated.
