2 members (carbking, TUTS 59),
108
Mod | | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 37 | I recently bought a new ingersorand air compressor and i bought a Daul action sander. I am going to remove the cab on my 1949 3600 and i am trying to figure out if i should sand blast it or DA it. i heard that sandblasting sheetmetal warps it so i want to double check with the pros. If i do sand the hood and fenders to get all the paint off to bare metal, what grit should i use medium or fine? please let me know. i really appreciate all your feedback since i am such a newbie at this. | | | | | Joined: Feb 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 52 | I did mine with 80grit pads before I got my sandblaster.
Kenny B. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I would ask myself how much time and effort do I want to put into this cab vs. money. Media (not sand) blasting is a quick and effective way to get the job done, but it cost $$$. There are other media products one may use instead of sand and these will not warp body panels in the right hands. If you are doing a frame or prepared axle then sand or aluminum oxide (the product we really use) will do the work. Soda ash is not a good option if you have seams as it is caustic and may/will cause problems down the road. Like 551st3800 I will use a hand held sander on small parts as it's faster than driving to the shop.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 80 grit is good-rough enough to do the job but not rough enough to get a novice in trouble. Wear a dust mask or respirator. Brian | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I use what is known as a "Hog" a 9 inch pad that uses self sticking disc, made by the same people that make the DA sander...Each disc is close to $2, but 2 disc in 40 grit will strip an entire hood...Its a low rpm machine that takes more air than a small compressor can put out...and it grinds, does not occellate..You are going to be using a ton of 80 grit paper...it would be My suggestion to drop to 40 grit and save Yourself some money...40 grit on a occelating DA sander will not leave grind marks as some want You to believe....Bill B | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Sand and a few other medias will warp sheetmetal. Personally the best media would be plastic. Plastic will not harm the metal, but it does NOT remove rust. Most media blasters first use plastic to remove the paint then come back with glass beads and remove the rust.
I would NOT use soda.
I would have the truck media blasted, I think the cost greatly outweighs the time and effort thats involved in sanding. Also I would not send the entire truck to the blaster at once. Give him pieces,when you get them back you are not sitting on a complete truck thats in bare metal...Eric | | | | | Joined: Mar 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 37 | thanks alot for all your input. mike | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Paper is cheap, go with the 80 grit.
If need be, give it a light sand blasting later (emphasize light). | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | I usually use 80 grit, but you will find you go through a LOT of it. Let the paper do the work, when you notice it's not cutting very well, change paper. Don't torture yourself by trying to get every last little bit out of your paper. It's a waste of time, effort, and wear and tear on your sander/compressor. Do save some of the used disks for fine detail and hand sanding, used disks work good for that.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | two 40's make 80...  Bill B | | | | | Joined: Mar 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 37 | thanks alot for all the input. As soon as i get the cab off i am going to start sanding. thans alot ,mike | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If I'm not too late to add my $.02, I like to use 3M Scotch Brite paint stripper pads. They go on an arbor with velcro. Mount it in a drill and go to town! Strips very fast and will remove the rust too. I get mine from Menard's, but any hardware store will have them. This is what the pads look like. http://multimedia.mmm.com/mws/mediawebserver.dyn?6666660Zjcf6lVs6EVs6667L4c7rrrrQ-
Bill Burmeister | | |
