5 members (RLB, Guitplayer, Otto Skorzeny, carbking, 78buckshot), 148 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#1249244 01/02/2018 9:49 PM
Good Afternoon,
I am starting to gather all of the items that I am either going to replace or are just missing and I have been unable to find a complete list of bolt/fastener sizes. I am looking specifically for a 41 1/2 ton. Does such a list exist?
I was able to match a few hat I needed at the local hardware store. But am having a hard time with a few because they were missing or in real bad shape.
Here are a couple:
Rear Leaf spring seat bolts - these are 5/16-18 X 1 3/4" long and they have a flat tip head on them. There are 2 that hold the two halves together around the rear end. Do replacements for these exist anywhere? I stripped one out trying to remove it. I though about using a standard carriage bolt. Not sure if that will work.
The other one I cannot seen to find is the rear motor mount to frame cross member bolts. I think it is a 7/16, just not sure of the length.
Thanks!
Josh
McMaster-Carr more than likely has all your needs as far as nuts/Bolts is concerned. As far as a list goes, I bet someone will be along soon with a link.🛠
