| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 4 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 4 | Good Afternoon,
I am starting to gather all of the items that I am either going to replace or are just missing and I have been unable to find a complete list of bolt/fastener sizes. I am looking specifically for a 41 1/2 ton. Does such a list exist?
I was able to match a few hat I needed at the local hardware store. But am having a hard time with a few because they were missing or in real bad shape.
Here are a couple:
Rear Leaf spring seat bolts - these are 5/16-18 X 1 3/4" long and they have a flat tip head on them. There are 2 that hold the two halves together around the rear end. Do replacements for these exist anywhere? I stripped one out trying to remove it. I though about using a standard carriage bolt. Not sure if that will work.
The other one I cannot seen to find is the rear motor mount to frame cross member bolts. I think it is a 7/16, just not sure of the length.
Thanks!
Josh | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | McMaster-Carr more than likely has all your needs as far as nuts/Bolts is concerned. As far as a list goes, I bet someone will be along soon with a link.ðŸ›
