BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
1 members (Truckrolet),
510
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,268 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Dec 2017 Posts: 4 New Guy | New Guy Joined: Dec 2017 Posts: 4 | I'm new to this site so don't know my way around yet I know it's been posted on here and I have look but came up short. I started 2 months ago installing ifs and irs off a 82 Jaguar xj6. I got to say the ifs was scary close to fit just setting the frame I wanted to use the jags OEM rubber mounts this left me with three places per side that needed fab work. 1st A arm need to clear the frame on the top side.2nd just below the A arms the frame need to be tapered in about 1". 3rd I use some tabs for the front OEM rubber mounts. On the IRS I C notch the back and fit the hole OEM cradle in. I have pictures and some Videos if some one would like to see. If anyone has install this set up and have there truck on the road I like some feedback on how it rides??? I'm a long way out before the tires hit the road.
Onebad58
| | | | Joined: Dec 2017 Posts: 4 New Guy | New Guy Joined: Dec 2017 Posts: 4 | Thanks that truck looks great. I'm struggling with the back control arms im guess that's what there called I'm wondering if I make my own and move them inbord of the bottom shock if they would hit the cradle under full suspension compression. I just don't like the stock one at all. My other idea is make some tabs that would straddle and stick out past the bottom shock bolt. Did you do something different here any ideas would be appreciated?
Onebad58
| | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | Messing with the geometry of an independent suspension system that has worked for years sort of defeats the purpose of using it, doesn't it? I'm pretty sure the designers who built it that way had more funds and research facilities available to them than the average hotrodder with a torch, a sledgehammer and a welder. Badger, unless you have the necessary engineering expertise to design a suspension system from scratch, and a really good fabrication shop available to you like Coilover does, it's best to leave well enough alone. Jerry
| | | | Joined: Dec 2017 Posts: 4 New Guy | New Guy Joined: Dec 2017 Posts: 4 | Thanks for the input you guy's I'm sure I will come up with something. Jerry as far as the messing with the geometry I assure you I'm not changing anything it's just one more thing that has to be done for the install. The arms only uses is the keep the rear end from kicking out the back end under hard launches in round about way. I fully understand what your are saying this why I'm trying to keep it as close to OEM as possible.
Onebad58
| | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | Ok- - - -the "control arm" you mentioned got me off on a different track. You're probably describing a sway bar or Panhard rod, not something involved in establishing the up/down arc of the rear hub. Jerry
| | | | Joined: Jun 2007 Posts: 100 Shop Shark | Shop Shark Joined: Jun 2007 Posts: 100 | I'm new to this site I have pictures and some Videos if some one would like to see. Yes. We would like to see the pictures. Even though I've seen it in person a picture goes a long way in describing your control arms. Cause they are big ugly looking things on there now.
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor. 1953 2 ton parts truck Long Gone 1957 GMC LCF On 75 Cadillac Eldorado Frame Updated Feb 2021 | | |
