1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
I want to put a 4 speed with granny in my 55.1. I have a 3 speed lite duty in it now. There is no cross member support for my 3 speed tranny. Was there a support for the heavier 4 speed? Is it a cross member or some other sort of bracket? Thanks - Scott
55 1st Chev.
scott you musta been reading my mind. I was about to post the exact same question. My 66 has the 3 speed/no support in it and I'm going to a significantly larger MY6/89MM 4 speed and wondered if I needed a crossmember.
I think I'm going to be on the safe side and buy one I saw at Golden State parts for 50 bucks. It can only help.
I don't think you can go wrong if you go ahead and get one for your 4 speed. Overkill at best.
-ftyler
Yes, if it is more securely mounted, it will make the whole assembly stronger. cool
There was no rear support in 54/55-st for the 1/2 ton truck transmission (unless you had a HydraMatic transmission). The motor mounts and the frame crossbrace for the motor mounts changed in 1954, supposedly making the rear mount for the 3-sp and 4-sp transmission unnecessary.
I have never had one on my 1/2-ton '54 pickup and it had a 4-sp on it from the factory (no holes in the steering column for the 3-sp shifter box).
Tim
Not sure what you figure to accomplish by using a crossmember with a trans that has no mount for bolting it to.
Junior Member
Junior Member
I REPLACED THE 3 SPD TRANNY IN MY 53 W/ A SAGINAW
4 SPD OUT OF AN 82 PONTIAC FIREBIRD AND FABRICATED
A TRANNY X-MEMBER FOR IT BY USING A 1 1/2" SQUARE
TUBING AND BOLTED IT IN USING #8 NUTS AND BOLTS
JUST TO BE ON THE SAFE SIDE...ALOHA
tclederman, or anyone else....What are the proper numbers for the 4 spd original tranny type? The junk yard needs to know. Also any installation tips would be helpful. - Thanks for all replies!
55 1st Chev.
SM420
[img]http://www.jeeptech.com/convtrans/sm420/4202.jpg[/img] [img]http://www.jeeptech.com/convtrans/sm420/4205.jpg[/img]
The pictures came from these guys. http://www.jeeptech.com/convtrans/gm/gmsm420id.html
This page will tell you a little more about the trans.
http://www.novak-adapt.com/knowledge/sm420.htm
If you want to go to the later SM465 like I did, you have to change bellhousing.
You can see it is as Jack said about the mount.
'67 GMC 3/4 292 4spd
Wow!!!That is more than I could have hoped for....
Thanks much Richard!
55 1st Chev.
SM420 (reverse is to the left) does not require a rear mount. All support is through the bell housing. If you get the SM465 (reverse is to the right) which is a newer tranny, a rear mount is required. You can use your existing bell housing, but you will have to machine to enlarge the cutout. Bolts are in the same place, though. Either one is a good box, parts for the SM465 are easier to get, they were built from about 67 to 79. Iirc, they also take different pressure plates.
Fred
52 3600
69 C-10
Anonymous
Unregistered
Anonymous
Unregistered
"There was no rear support in 54/55-st for the 1/2 ton truck transmission (unless you had a HydraMatic transmission)."
I dont agree TC. I just parted out a 54 1/2 ton with a 4 speed & it did have the rear trans. crossmember . These mounts are avaliable if you put a want ad in the Swapmeet section wink
I thought it was a simple question. Why is it I can't get a simple answer? Do they have a cross member supporting the 4 spd. tranny SM420? How can this be a point of contention? Thanks!
55 1st Chev.
Simple Answer
1955 no mount
1947-54 had a mount
So in your case being a 1955 no mount
no crossmember for 1955 sm420
Mike
Thanks!
55 1st Chev.
Being pedantic (again):
Both the 1954 and 1955-first-series 1/2 ton truck had no transmission mount unless it had a HydraMatic transmission.
This correction is no change to the information pertinent to scdascda but is a slight change to the Simple Answer above.
Tim
