| | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Just how cold are you Bolters seeing these days and future winter months arriving. Just returned back from my place in Bridgeport Calif. and I was seeing pretty close to 0. I'm not quite sure at say 0 - 10 degrees would my 235' require in gallons of antifreeze to keep her from ruining my Christmas New years holiday. I checked it with one of those there 4 different colored plastic bubble gauge and it showed about 20 degrees? I'm planning on draining the water and refilling it with fresh water and of course the antifreeze. Thank you....... | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I always use 50% antifreeze and 50% distilled water, then I don't worry.
Ed
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | First- - - -be sure the whole engine, not just the radiator gets drained. The position of the water pump inlet on a stovebolt allows a lot of coolant (water) to stay trapped in the block. The block drain is down low on the water jacket at the driver's side rear, and sometimes it takes a bit of poking and prodding of the crud in the block to get it to flow.
Once the block is empty, refill the cooling system with a 50:50 mix of antifreeze and water. That mix is good to -37 degrees F. If you're lazy and want to pay antifreeze prices for water, 50:50 pre-mixed coolant is available. If it gets colder than that here in Tennessee, I'm moving to Tahiti! Jerry
