0 members (),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Those of you who have original-ish AD trucks with the frame bracket/strap holder...
Does the muffler sit more or less level with the frame? Or is it tilted front to back?
1951 3100
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I never saw muffler's that were not level. Jeffrey | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Thanks, that's what I was assuming. But the original pipe is disconnected, nothing to compare to, and the hanger allows tons of flexibility.
I have the bent manifold-to-muffler and tailpipes, each cut long for fitting. Will have to cut them to the proper length to get muffler level. Muffler is not quite stock length and offset....so lots of variables in play.
1951 3100
