4 members (Southerntruck, Hotrod Lincoln, 52Carl, TUTS 59), 92 guests, and 1 robot.
Topics128,162
Posts1,056,932
Members48,458
Those of you who have original-ish AD trucks with the frame bracket/strap holder...
Does the muffler sit more or less level with the frame? Or is it tilted front to back?
1951 3100
I never saw muffler's that were not level.
Jeffrey
Thanks, that's what I was assuming. But the original pipe is disconnected, nothing to compare to, and the hanger allows tons of flexibility.
I have the bent manifold-to-muffler and tailpipes, each cut long for fitting. Will have to cut them to the proper length to get muffler level. Muffler is not quite stock length and offset....so lots of variables in play.
1951 3100
