7 members (Otto Skorzeny, Southerntruck, Guitplayer, Hotrod Lincoln, 52Carl, qside, 1 invisible),
160
Mod | | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | I've got a question about the body fit on my 52 GMC burb. I got a used chrome grill off of ebay last year and am finally getting around to putting it on. It seems to be slightly off center and one side sticks out about a 1/2 inch farther than the other, The doors almost fit square in the openings , but not quite and barn door gaps are impossible to line up like I like them. Am I expecting too much to expect better alignment? Is this normal or has mine been washed and put away wet and it has wrinkled? | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | smitty i would not say used up , but used. these ol truckes, burbs and panels were hand made compared to modern vehicles. I have 4 passenger side doors for my panel and not one "fits" the same as the other. and my barn doors, same thing, but i am getting closer with a tweak here and there. good luck tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Ther are some tricks depending on where you are with the truck. Up and runnung or in rebuilding process?
| | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | My truck is a daily driver that I am tweaking for a new paint job. I am fixing windows, new felts and all rubber parts. New weatherstriping and windlace will be installed. I just want it to be as good as I can get it! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | keep tweaking - at the factory if they tried a door and it was off, they could just set it aside and try another, until one fit well enuff to be tuned in with the hinges ... the rejects would fit better on another truck down the line ... you can do a lot with hinge adjustments and a bit more slamming it on chunk of 2x4 hinge side or latch side Bill | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I had the same deal with the pass door. 1 didn't fit so I tried another. I also had to tweak the opening with a porta power to get it aligned right. Now my gaps are perfect. 1/8th in. front and back. | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | smittyschevy, back in the production days it seemed as though uniform fits were not priority.. I took lots of time in getting the "gaps" uniform. On the right door, for example, the rear door edge was almost over-lapping the cab..the door opening measured correctly...So to obtain a proper fit, the door edge was reduced considerably with a grinder, then with a 2 solid copper bars sandwiched the door edge, then mig welded a bead on the door edge and worked it down to the gap I desired...It was alot of work, but I got the results I was looking for...Good luck...Bill B | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Thanks to all for the good advice. I guess that I will tweak here and there and be glad that my doors shut good and i've got no rust. Smitty | | |
