0 members (), 151 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#124801 03/02/2007 3:34 AM
I've got a question about the body fit on my 52 GMC burb. I got a used chrome grill off of ebay last year and am finally getting around to putting it on. It seems to be slightly off center and one side sticks out about a 1/2 inch farther than the other, The doors almost fit square in the openings , but not quite and barn door gaps are impossible to line up like I like them. Am I expecting too much to expect better alignment? Is this normal or has mine been washed and put away wet and it has wrinkled?
#124802 03/04/2007 3:13 AM
smitty
i would not say used up , but used.
these ol truckes, burbs and panels were hand made compared to modern vehicles. I have 4 passenger side doors for my panel and not one "fits" the same as the other. and my barn doors, same thing, but i am getting closer with a tweak here and there. good luck
tom
I don't suffer from insanity, I enjoy every minute of it!
#124803 03/04/2007 3:41 AM
Ther are some tricks depending on where you are with the truck. Up and runnung or in rebuilding process?
#124804 03/04/2007 5:22 AM
My truck is a daily driver that I am tweaking for a new paint job. I am fixing windows, new felts and all rubber parts. New weatherstriping and windlace will be installed. I just want it to be as good as I can get it!
#124805 03/04/2007 5:51 AM
keep tweaking - at the factory if they tried a door and it was off, they could just set it aside and try another, until one fit well enuff to be tuned in with the hinges ... the rejects would fit better on another truck down the line ... you can do a lot with hinge adjustments and a bit more slamming it on chunk of 2x4 hinge side or latch side grin
#124806 03/04/2007 6:08 PM
I had the same deal with the pass door. 1 didn't fit so I tried another. I also had to tweak the opening with a porta power to get it aligned right. Now my gaps are perfect. 1/8th in. front and back.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#124807 03/04/2007 6:15 PM
smittyschevy, back in the production days it
seemed as though uniform fits were not priority..
I took lots of time in getting the "gaps" uniform. On the right door, for example, the rear
door edge was almost over-lapping the cab..the door
opening measured correctly...So to obtain a proper fit, the door edge was reduced considerably with a
grinder, then with a 2 solid copper bars sandwiched
the door edge, then mig welded a bead on the door
edge and worked it down to the gap I desired...It was alot of work, but I got the results I was looking for...Good luck...Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#124808 03/05/2007 1:20 AM
Thanks to all for the good advice. I guess that I will tweak here and there and be glad that my doors shut good and i've got no rust. Smitty
