5 members (Gray_Ghost, GMCJammer51, Otto Skorzeny, Paul Mullen, Jon G), 172 guests, and 5 robots.
Topics128,078
Posts1,056,046
Members48,433
#1247937 12/23/2017 10:22 PM
Putting the cab for 38 half ton on new, custom frame. The cab was fastened to the original frame with 3 bolts on each side - one “under” the cowl (kick plate area); one near front of seat; and one under the seat. Chevy of 40s appears to sell aftermarket block/shim kit for the front, under cowl bolt area. I don’t see anything for the other two connection points. When I pulled the cab, it looks like there were rubber bed shims at all three connection points.
Question- what do folks normally use for the connection points between the cab and the frame, particularly the back two points?
back yard wrench turner
My '38 1 ton had rubber insulators in each area also. The rear connection has a bolt with a spring making the body suspended above the frame. I presume this is to allow for the frame to flex under the body.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Thanks!!
