| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Putting the cab for 38 half ton on new, custom frame. The cab was fastened to the original frame with 3 bolts on each side - one “under” the cowl (kick plate area); one near front of seat; and one under the seat. Chevy of 40s appears to sell aftermarket block/shim kit for the front, under cowl bolt area. I don’t see anything for the other two connection points. When I pulled the cab, it looks like there were rubber bed shims at all three connection points.
Question- what do folks normally use for the connection points between the cab and the frame, particularly the back two points?
| | | | | Joined: Sep 2010 Posts: 1,706 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,706 | My '38 1 ton had rubber insulators in each area also. The rear connection has a bolt with a spring making the body suspended above the frame. I presume this is to allow for the frame to flex under the body. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | | | |
