4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#1247895 12/23/2017 2:34 PM
Another attempt to post pictures of my 292 motor mounts.
mick53 #1247897 12/23/2017 3:05 PM
Nice job on the mounts. I need to do the same thing I think. I'm going to put a 67 292 engine in my '49 4400 1 1/2 this winter if I can make it fit. Someone said I would have to move the radiator foreward too but I haven't gotten that far yet , still working on the body.
mick53 #1247918 12/23/2017 6:08 PM
That is a good looking setup- - - -is it home built or commercial? Do you plan to weld or bolt the adapters to the frame? Back when I was working with big rigs, we made it a practice NOT to weld or drill on the frame flanges to attach anything. It creates stress points that can lead to cracks and/or frame rail breakage. I'd suggest drilling holes in the vertical area of the frame and using sleeves over the bolts to position the mount brackets. That might be getting a little too picky, but that's how we mounted things like 5th. wheels, etc. on the big rigs.
KingG #1247931 12/23/2017 8:34 PM
I think the 292 is 3" longer. I have been told you can just move the radiator to the front of the mount. There are smarter people here than me that can tell you that. I will have to move mine into the cab a little because of the 3" blower pulley. I had these mounts made. I think it was classic chassis but not sure. will have to go through my paperwork. I have heard that welding is not the best way to mount. Maybe box the frame? What about hot rivets?
mick53 #1247932 12/23/2017 8:50 PM
Frame boxing is a surefire way to get it so rigid it cracks. We finally decided to bolt on everything except the roll cage after many years of patching stress cracks on the dirt track cars. We needed enough rigidity so spring rate adjustments would result in predictable handling changes, but the frame needs to flex a little on a street machine. Going from full throttle to idle several times a lap with a 600+ HP engine on a surface that resembled a motocross track after a couple of heat races had a habit of finding the weak spots.
mick53 #1247938 12/23/2017 10:30 PM
Crusing in the Passing Lane
GM 194-230-250-292 are about the same length as a GMC 6, so no need to move anything if one has a GMC truck. Chevy trucks need to move the radiator into the core support-take a look at a GMC to get ideas.
ED
mick53 #1247970 12/24/2017 5:04 AM
Thanks for the advice. Of course now I have no idea how to attach the motor mounts.
mick53 #1247972 12/24/2017 5:12 AM
Drop me a PM with your email address- - - -I can sketch out some ideas that might work and send them as an attachment.
wont let me PM you. my email is [email protected]
mick53 #1248054 12/24/2017 9:51 PM
Looks like the PM went through from my end.
mick53 #1248058 12/24/2017 10:20 PM
I made a front mount for my 292 in my 1954 Chevy 3100 and used a 1965 chevy truck bell housing that bolted in the original location. I didnt have to move my radiator at all but its a tight fit. Though I had to put in an electric fan in the front of the radiator.
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
mick53 #1248197 12/26/2017 1:36 AM
Beast54 , that looks like what I need to do on mine. Would rather go that route using the front mount than doing any mods to my frame work on putting the 292 in my '49 4400. You didn't happen to save the pattern did ya?
mick53 #1248327 12/27/2017 3:31 AM
Yes I do have the pattern and boy was it a little tricky to make! It took a few tries to get it perfect. But its strong enought to handle over 400 ftlbs of torque. I made the mount to bolt up to the stock bolt holes on the frame with the 235 i had in there. The rubber mount i got at NAPA, it was from a Ford V10 motor mount. I did have to cut the mount a little shorter and drill an extra hole. The 65 Chevy truck bell housing was a 1/2 inch farther back than the stock 235 one. I did have to beat my firewall a little to give the 292 a little more clearance. You might want to try a 55-59 truck V8 bell housing. But with that thought your water pump pully might touch your raidiator.
62401
Jerry -- You can send me those sketches if you like and we can turn them into a tech tip perhaps -- seems like there's a lot more discussion about the later engines these days as the supplies of 261's and 302's are drying up .... Maybe there's a lot of 'Bolters out there who would be interested in running a 292 in their truck?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
mick53 #1248378 12/27/2017 5:12 PM
I replied to your new thread about installing the 3rd.-greneration inline engines into earlier model trucks. I'll see if I can add a link to that one. My main concern in suggesting an alternative mounting method was avoiding welding or bolting mount brackets onto the frame rail flanges. We used a procedure on the big rigs for mounting accessories that involved drilling and bolting brackets to the vertical areas of the frame rails, NOT the flanges!
Hi, I've wound up with the front mount adapter for a 292 and as it's late tonight I will get a dimensioned picture/drawing out to you tomorrow, Have Eric tell you about the engine work he had done, sweet 292...
Ted
Ted
1950 Styleline 2-door with 261
1951 Truck 3100 with 235
Ted,Eric,
I would also be interested in dimensions and drawing as I am going with a 292 in my 1951 and have been looking for different options to mount it.
Thanks Dave
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block)
1951 GMC 9434 5 Window (waiting on a 292 transplant)
mick53 #1248494 12/28/2017 2:46 PM
John[/quote]
I too would like to see them Thanks all
I have a 55 second gen!,, work in progress
1963 long bed step side driver
Just a guy who digs old trucks!
mick53 #1248566 12/29/2017 3:50 AM
We can also trace the template on some cardstock or something and mail that out if that works. Here is what ive done to my 292:
Chevrolet High Torque 292
300+ HP 400+ Torque
Block: 1974 Chevy 292
Crank- Polished
Cam- Clifford 264 Hot Street
Bored .040 (298 CI)
High Compression Forged Racing Pistons
Zero Decked
65K HEI Distributor
Chrome Moly Push Rods
Head: 1966 Chevy 250
Machined .030
Oversized Stainless Steel Valves 1.94/1.60
Bolt Bosses Removed
Premium Hi-Flo Lump Port Kit
Big Block Roller Rockers
Port and Polished
Offenhouser 4bbl Intake
Edelbrock 600 CFM Carb
Pace Setter Full Length Tube Headers
12" Heavy Duty Clutch
mick53 #1248592 12/29/2017 9:06 AM
Hello!
I`m also figuring out how to put 292 to my -52 one ton. been searching front mount all over, with no luck, I even bought one horseshoe mount to be modified, did not work.
So I would also be interested the pattern for the front mount . I made the side mounts and have the early v-8 bell housing, but maybe the front mount works better with bell housing mounting.
-At least that`s the way the motor is originally mounted on these trucks.
-Rane
mick53 #1248954 12/31/2017 9:30 PM
I have a dimensioned copy of the original metal adapter, how do I attach a copy?
Ted
The copy is terrible, send me an email address and I will mail you a full size copy.
Ted
Ted
mick53 #1248962 12/31/2017 10:54 PM
my email: [email protected], thanks very much, and good new year!
rane
mick53 #1249413 01/04/2018 1:43 AM
Thirdtimer, I would also Iike a copy of the pattern. Can e-mail to [email protected], thank you
mick53 #1267866 06/02/2018 5:34 AM
I think the front motor mount is a great idea in that it uses the stock position but are there any concerns with its strength and the amount of stress placed on it with such a high torque engine?
1950 Chevrolet 1/2-Ton 3100
mick53 #1267878 06/02/2018 12:56 PM
Sucking fans are more efficient than pusher fans; since 292's and their brothers are longer than 235's, etc., in Chevy's, ( GMC do not have this problem) it would be a good idea to move the radiator forward slightly in the core support to be able to use an original fan, give more room for accessories. For additional heat capacity, use a fan shroud, with a rolled edge around the fan, fan blades should be centered in shroud. Holes in shroud should have flaps of some heavy material to open when road air pushes them open-see-VW Rabbit, etc.
Neoprene mount material is readily available in 1" thick by 4" wide by length as snowplow blade material; Florida residents will have to look elsewhere.
Ed.
mick53 #1267904 06/02/2018 6:58 PM
I see you used the Flathead Ford mount cushions which in my opinion are as good as any ever made. I use then for all motor mounts and many transmission mounts. On my straight eight Buick the engine really rocked and rolled with the factory mounts so I welded some extensions to the timing cover mount plate and used the flathead cushions. No more rocking.
[img]https://s22.postimg.cc/noddniei5/Straight_8_a-c_mount_001.jpg[/img]
[img]https://s22.postimg.cc/7dd9ra219/Straight_8_a-c_mount_002.jpg[/img]
Evan
mick53 #1273446 07/23/2018 2:25 AM
ASU Offline
I am looking to put a 292 in my 48 3600. I like the idea of the horseshoe front mount, but I am lost on the rear mounts. My 292 has a bell housing with the angled mounts. My current 235 has the flat mounts. I have found pictures of how to notch and weld the 48 cross member to match up to the angled bell housing. I cannot find motor mounts to put between the bell housing and cross member. Any suggestions?
Thanks Jon
Thirdtimer: I'm working on getting a 292 set up to install in my 1951 3800. I found this post from several years ago that shows pics and dimensions for a front motor mount. Looks to me like it would be a whole lot simpler and cleaner than the side mounts I have seen in other posts. If you still have this information, I would be obliged if you could send it to me so I can fab one up for my own use. Email is [email protected] Thanks. Mike Jury, North Carolina
mick53 #1404310 04/01/2021 11:13 PM
Thirdtimer hasn’t been around for over 3 years. I doubt you will get a response.
mick53 #1404313 04/01/2021 11:16 PM
Electric blowing fans are less efficient than sucking fans?
Ed
mick53 #1404382 04/02/2021 12:34 PM
My 292 has side mounts and transmission mount. If you use a front mount and a transmission mount is that going to put more pressure on the bell housing due to the longer distance between the mounts vs the side mounts that are more centered on the engine?
mick53 #1404389 04/02/2021 1:10 PM
Mick 53 I always welded mine,and welded them for friends we never had any cracks this was on daily drivers.
mick53 #1410200 05/17/2021 1:14 PM
Hey everyone. just an FYI Thirdtimer had passed away. He was a very dear friend of mine. I now have the template for the 292 front mount. We both designed and built it together. I put a 292 into in my 54 Chevy truck. If anyone wants a copy I can mail one. [email protected]
mick53 #1410203 05/17/2021 1:21 PM
From my experience with the blowing/sucking fans, with my build I used an aluminum 3 core radiator with a push fan and had no problems
