1 members (GRNHydra), 161 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
#1238913 10/12/2017 3:04 AM
Moderated
Moderated
I have a 1950 chevy truck and thinking about making it into a hauler , wrecker . Buy putting it on a 1970 1 ton dually frame with a Ls engine that I have. The only thing that concerns me is the front 1 ton suspension. I am thinking by doing this, the front stock dually wheels will stick out of the wheel wells. similar to most 4 wheel drives. But that's not what I want. Rather have them under the fenders. Normal looking. Also use the dually wheels to match the rear. I had plenty of ideas. But I am not sure what will work. Like using the suspension from a single wheel one ton, or 3/4 ton. then using front adapters to match the bolt pattern. As I remember the single 1 ton and the 3/4 ton do not have as wide of a track as a dually. Also seem like the 1 ton spindles and hubs are a lot wider then single wheel and 3/4. making the track wider. Anyone done something similar ? Or have Ideas.
THANKS !
Off hand, I’m going to say the later chassis will be a little wide. The 4100 and larger trucks had wider and longer fenders. It may be worthwhile to find a “Big Bolt” donor. I’ve also seen the low rider guys narrow their control arms. Unless you’re bagging it, I would guess it would create a terrible ride.
Is your 1950 a 3800 truck? In my opinion, the 3800 trucks are beefier than even the late model trucks.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Crusing in the Passing Lane
AD front fenders can be widened by a good 'tin man' by just adding a 3 or 4" piece in the flattest spot. Way lot safer and easier than shortening control arms.
Ed
Use the front sheet metal off a 1 1/2 ton or bigger truck. The fenders are wider to begin with, the wheel openings are larger, and the same trick of adding a strip of metal to the fender in a fairly straight section can be done with the wider fenders if necessary.
I measured 1.5 or 2 ton AD front fenders (on the truck) to be 72" wide inside to inside of the lip at the bottom edge both front and rear of the wheel opening. Don’t have my notes handy for the small trucks.
I’m thinking the fenders aren’t actually much or any wider on the AD big trucks compared to the small ones.
Until you get up to the 400 series GMC, those fenders are noticeably wider.
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg,if you look between the headlight and grill on the 1 ton and 1.5 ton you can see the difference.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Measuring my 1 ton same as I did the 2 ton it’s about 69-70” inside lower lips of front fenders (not most accurate, measured by myself).
So the 1.5 and 2 tons are about 2-3” wider under front fenders than the little trucks.
Not much.
---All pictures---
Moderated by  Dusty53
