6 members (greenie-reddy, FAST55, MRMEROTH11, Otto Skorzeny, 1955 1 Series, Hotrod Lincoln), 107 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1247757 12/21/2017 11:31 PM
Who do you like did you do the two or four wheel installation? I have read some will not work with stock wheels? Like to hear your thoughts!
I have a 55 second gen!,, work in progress
1963 long bed step side driver
Just a guy who digs old trucks!
I bought the CPP kit. I got the kit that uses the factory ball joints, 7/16” wheel studs, and standard height spindle. I bought my kit through Summit and shipping was free. The caliper will barely clear my 15” aluminum slots but I can’t use any stick-on wheel balancing weights inside the wheel.
I have read over and over again that NONE of the front disc brake kits will allow you to use the factory 1960-66 wheels. However, a set of 1967-72 six lug K10 wheels WILL FIT. I’m pretty sure the 15” Vintiques wheels will also fit over the calipers. A friend of mine says he got the factory wheels to fit by using a wheel spacer. However, I don’t like that option.
I too do not like the spacer idea,, I wonder if its possible to grind off a corner of the caliper, having not seen the install that is just a guess
