Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (G508, dt235sd, DoubleB), 173 guests, and 4 robots.
Topics128,277
Posts1,058,441
Members48,490
#1246001 12/06/2017 8:15 PM
so, I'm putting a danforth front crossmember with colorado suspension under 1950 3100.
the crossmember will lower frame an inch . will the extra weight of the 3100 with a v8 make
standard springs compress more thus lowering the front end more? I'm wanting 2 to 3 inch drop when all is said and done .
Thanks for the input. charles
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
When I did the danforth swap I had to try various springs to get it where i wanted it. I ended up with moog 5660 and cut off a half coil
it gave us this stance
http://www.thehollisterroadcompany.com/gallery.html down toward the bottom, the wheels are 18x8
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
