4 members (68ironhead, Wayne67vert, GRNHydra, Oswald), 131 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#1247242 12/17/2017 10:33 PM
What's the best tool way to remove the frame rivit son my 50 3100 frame. Rear upper shock mounts and running board brackets. Thanks for any help
flattop49 #1247244 12/17/2017 10:42 PM
Tried torch, grinder, and cutting wheels on a few. And then used big hammer and cold chisel. If you have room, hammer and chisel was the way to go.
~ HB
1962 Chevrolet C10
1962 Suburban
flattop49 #1247248 12/17/2017 11:04 PM
Center punch the rivet head as close to the middle as possible, drill most of the head away and chisel the remaining shell off. A drift punch will drive the remainder out easily.
flattop49 #1247253 12/17/2017 11:21 PM
Fox Offline
Hold on to that chisel with a pair of vise grips and put on a face mask! I've done it that way, but prefer to punch and drill as Jerry said.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
flattop49 #1247254 12/17/2017 11:22 PM
I recently removed the very rivets of which you speak (there are lots of them).
HRL's method is what I used. The rivet heads are crowned and some are irregular, so I used a small angle grinder to make a flat spot which makes finding the center easier, then did what HRL recommends.
Carl
flattop49 #1247257 12/17/2017 11:27 PM
If the parts are going to be reattached with bolts, I strongly recommend precision-reaming the holes and using shouldered Allen head bolts to eliminate any slack between the parts. That's particularly true if you're working with stressed parts like crossmembers.
flattop49 #1247272 12/18/2017 1:16 AM
I strongly reinforce the comment about eye protection.
I was 17 and working under my '63 drilling out cross member rivots so I could relocate the cross member with the rear transmission mount to change from the Power Glide to the TH400. No eye protection.
The doctor ended up taking 11 pieces of metal out of my right eye. They left the 12th piece in because it had already sealed over. It eventually dissolved, but I have had trouble with that eye ever since.
Eye protection is cheap insurance.
flattop49 #1247275 12/18/2017 1:30 AM
Thanks for the advice. Sounds like good bit, hammer and chisel will be the ticket. Thanks again for eye protection advise.
flattop49 #1247455 12/19/2017 12:07 PM
62401
On the hammer and cold chisel, go big. I started trying that method with a heavy ball peen hammer and a standard (small) chisel (top combo in attached photo) with frustrating results.
Once I switched to a bigger hammer, and the largest cold chisel I could hang on to, I enjoyed much more success.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
flattop49 #1247460 12/19/2017 12:50 PM
Up to about a 3/8” rivet best method I’ve found is large long cold chisel and as big a hammer as you can swing with the other hand.
Drilling works too, but big hammer is way faster/simpler.
1952 Chevrolet 3800 pickup
---All pictures---
flattop49 #1247471 12/19/2017 2:22 PM
Reminds me. I picked up this guy not too long ago and have used it on occasion. It seems to do the job.
https://store.snapon.com/Demolition...le-Demolition-18-Red-Chisel-P651245.aspx
flattop49 #1247510 12/19/2017 6:40 PM
Here's the other way I remove rivets, loud but effective.
https://photos.app.goo.gl/ClgutIJOQdRbeVX72
---All pictures---
flattop49 #1247572 12/20/2017 4:47 AM
J M Offline
I use my air chisel, and then punch them out with a punch in the air hammer.
Jim
Moderated by  MNSmith
